TwinTurbo.NET: Nissan 300ZX forum - Re: are you pulling any codes??
puddlejumpinzx
on June 06, 2008 at 7:56 PM
are you pulling any codes?? (n/m)
posted by twinturbineZ
on June 06, 2008 at 07:25 PM
We are getting a code from the CAS but not sure why. It ran before with the ECU stock but now it's Ash spec so could that be the culprit?
Z won't start...
puddlejumpinzx
18:09:25 06/06/08
Did you plug in the temp sensors...and MAF? (n/m)
twinturbineZ
18:29:00 06/06/08
Re: Did you plug in the temp sensors...and MAF?
puddlejumpinzx
18:36:11 06/06/08
Check the PTU..is there spark..fuel..getting to
twinturbineZ
19:19:44 06/06/08
twinturbineZ
19:25:40 06/06/08
Re: are you pulling any codes?? -
puddlejumpinzx
19:56:14 06/06/08
RShouldn't be..however..just check the CAS connection
twinturbineZ
20:48:14 06/06/08
Re: RShouldn't be..however..just check the CAS connection
puddlejumpinzx
21:08:15 06/06/08
check the center or middle wire on the coil connector
twinturbineZ
23:03:20 06/06/08
Re: check the center or middle wire on the coil connector
puddlejumpinzx
01:55:39 06/07/08
That's not what I told you to do! I said...check
twinturbineZ
15:45:44 06/07/08
clean the CAS and PTU connectors, especially the CAS
fanta-z
12:01:24 06/07/08
